Oziexplorer - to - OruxMaps
OdgovorNapisal/-a cdejan » 29 Nov 2012 19:21
Trudim se z batch koverzijo "Ozi kalibriranih" map s programom OruxMaps Desktop .
V *.map file-ih imam naslednje
1 ,Map Code,
Koda: SLOVENIJA,WGS 84, 0.0000, 0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy, 0, 0,in, deg, 45, 59.9988,N, 13, 59.8650,E, grid, , , ,
Point02,xy, 4657, 6617,in, deg, 45, 52.4991,N, 14, 7.6209,E, grid, , , ,
Point30,xy, , ,in, deg, , ,, , ,, grid, , , ,
Projection Setup, 0.000000000, 15.000000000, 0.999900000, 500000.00, -5000000.00, 34.000000000, 40.500000000,,,
Map Feature = MF ; Map Comment = MC These follow if they exist
Track File = TF These follow if they exist
Moving Map Parameters = MM? These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2,4657,0
MMPXY,3,4657,6617
MMPXY,4,0,6617
MMPLL,1, 13.997750, 45.999980
MMPLL,2, 14.125035, 46.001025
MMPLL,3, 14.127015, 45.874985
MMPLL,4, 14.000018, 45.873944
MM1B,2.116381
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,4657,6617
Kaj moram vpisati v datoteko datums.txt ??
Poskusil sem vse žive kombinacije
SLOVENIJA|Slovenia|Bessel 1841|668.0|-205.0|472.0|0.000000|0.000000|0.000000|0.000000
Slovenja|SLOVENIJA|Bessel 1841|668.0|-205.0|472.0|0.000000|0.000000|0.000000|0.000000
Koda Slovenja|Koda: SLOVENIJA|Bessel 1841|668.0|-205.0|472.0|0.000000|0.000000|0.000000|0.000000
Pa brez uspeha .. vedno dobim
Failed:C:\Users\dejancolja\user\temp\291100.map Unknown Datum!!!!
OK---->C:\Users\dejancolja\user\temp\b2.map!!!
Failed:C:\Users\dejancolja\user\temp\C052400.map Unknown Datum!!!!
Verjetno je treba še kaj vnesti v Ozi2Orux.txt ???
Zelo bi bil hvaležen za kakšen namig, da se končno premaknem iz mrtve točke.
Pozdrav Dejan
cdejan
Prispevkov: 45
Pridružen: 02 Nov 2007 20:18
Re: Oziexplorer - to - OruxMaps
OdgovorNapisal/-a Tomo » 29 Nov 2012 19:29
OdgovorNapisal/-a cdejan » 29 Nov 2012 22:49
Hvala !
Moj datums.txt je zdaj tak ..
Corrego Alegre|Brazil|International 1924|-206.000000|172.000000|-6.000000|0.000000|0.000000|0.000000|0.000000
D-48|Slovenija|Bessel 1841|668|-205|472|0.000000|0.000000|0.000000|0.000000
Dabola|Guinea|Clarke 1880|-83.000000|37.000000|124.000000|0.000000|0.000000|0.000000|0.000000
Ampak rezultat je isti ..
Files found:3
cdejan
Prispevkov: 45
OdgovorNapisal/-a Tomo » 29 Nov 2012 22:54
Datoteka datums.dat mora biti na imeniku programa, ne map.
OdgovorNapisal/-a cdejan » 30 Nov 2012 10:21
Uporabljam verzijo 2.0.20beta. Lokacija datotek je naslednja .. Ti omenjaš datums.dat ? Tu v OruxMapsDesktop je namreč datums.txt ?
Directory of c:\..\OruxMapsDesktop
29.11.12 22:52 <DIR> .
29.11.12 22:52 <DIR> ..
29.11.12 22:52 29.266 datums.txt
29.11.12 22:50 29.352 datums.txt.bak
26.11.12 23:30 29.285 datums_orig.txt
26.11.12 23:30 441 leeme.txt
28.11.12 18:54 <DIR> lib
26.11.12 23:30 485.460 okmdatums.xml
26.11.12 23:30 39 OruxMapsDesktop.bat
26.11.12 23:30 600.302 OruxMapsDesktop.jar
26.11.12 23:30 40 OruxMapsDesktop.sh
26.11.12 23:30 547 Ozi2Orux.txt
26.11.12 23:30 410 readme.txt
Directory of c:\..\OziMaps
28.11.12 19:17 <DIR> .
28.11.12 19:17 <DIR> ..
20.07.07 16:05 3.809 291100.map
04.08.03 15:42 3.187.354 291100.png
19.02.07 10:27 3.951.146 b2.jpg
20.07.07 16:08 3.772 b2.map
06.05.11 20:52 3.805 C052400.map
07.01.04 11:54 2.453.726 C052400.png
29.11.12 22:55 <DIR> orux
cdejan
Prispevkov: 45
OdgovorNapisal/-a Tomo » 30 Nov 2012 10:28
Zatipkal sem se - mislil sem datums.txt - in kot vidim jo imaš na pravi lokaciji.
Ne morem več pogledat na računalnik na katerem se delal to, tako da ne vem kakšne datoteke sem dobil , isti datumi pa morajo biti v datoteki ozi2orux.txt le oblika je malo drugačna.
Glede na tip sporočila pa očitno nimaš vsega v tej ozi2orux, sicer ne bi javljal napake.
Vrni se na Navigacija
